Injector leaking
dawsy 22
Injector leaking
Hi all my 2.2 C5 Diesel has what I think is a leaking injector .The symptoms are that on idle the the engine revs slightly increase and straight away the e.m.l light comes on I have checked the fault with my lexi and the fault reason is low pressure.i have had it on the lexi today and on the live data screen 3 of the injectors are running at around 1 and the other 1 is running a negative. 2:16 on the flow correction hope this makes sense any help would be much appreciated
Thanks Ian
JamesQB
- x 5
Re: Injector leaking
It would seem the injector is sticking open or slow to shut off. That'd explain the negative correction and low rail pressure. I'd get a scrapyard injector and replace it, see if that cures it. Others might have different advice.
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
- x 1240
You can check them by connecting a length of plastic pipe from each injector leak off connection into four similar sized receptacle and checking the amount of leak off from each injector, they should all be more or less the same, if one is excessive that it likely to be the problem, this needs doing with a hot engine. If you have one passing excessive leak off although that might not be the problem it needs changing anyway.
dawsy 22
Thanks guys I have a spare injector which I will fit this week,one other question am I correct in thinking that number one injector is nearest to the cambelt.
Thanks Ian
Thanks Ian
Thanks Ian
- x 1060
On this engine number 4 is nearest the timing belt.
dawsy 22
Thanks wheeler I will be trying to remove the faulty injector tomorrow tried today but I don't think the engine was warm enough
Thanks Ian
