Wanted Aerial Amplifer information/location
howiedean
Unread post by howiedean »
I've just ordered a new aerial to replace the one on my C5 estate. The radio reception is currently very poor, I've checked the aerial behind the head unit and that looks ok. If the aerial doesnt cure the fault, can someone please explain where the amplifier is located?
Thank you,
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
dnsey
x 19
Re: Wanted Aerial Amplifer information/location
Unread post by dnsey »
It's in the base of the aerial, so if you've bought the whole thing, and not just the mast, you'll be replacing the amp anyway.
It's quite common for water to get into the base and stop the amp working, so a fair bet that replacement will solve the problem.
x 1994
Unread post by Stickyfinger »
Normally the aerial base board rots----or the earth is bad ---or both. Make sure the earthing connections are very clean.
howiedean
Ok, we'll see what arrives in the post then as I've ordered a small sharks fin type.
Thank you,
Howie
