Depressurising C5 with diagbox
osx
(Donor 2022)
x 15
Unread post by osx »
Is there a specific procedure or is it self explanatory with diagbox? Saw the option in one of the menus.
C5 X7 Exclusive 2.0 HDi Auto
x 1996
Re: Depressurising C5 with diagbox
Unread post by Stickyfinger »
just make sure your not under it or wish to get under it or have anything under it.
osx
(Donor 2022)
x 15
Not many instructions except from disconnecting the battery at the end. Should I have removed the LDS tank cap at any point?
osx
(Donor 2022)
x 15
Do I need to remove the cap at any point if I depressurise with diagbox?
Jodyone
x 3
Unread post by Jodyone »
It's generally thought to be a good idea to remove the cap. Later caps are vented, but the hole is very small and may not reduce pressure quickly enough. Also, be ready with lotsa rags or a turkey baster (or similar)- they're often overfilled, and you'll only find out when the tank overflows on service low... ask me how i know...
2006 C6 Exclusive, 2.7 HDi - Big Ron. Long gone!!
vborovic
Locked user account
x 40
Unread post by vborovic »
Really, how do you know that? ... :D
osx
(Donor 2022)
x 15
I did it with the cap removed and it didn't overflow but wanted to check if this is the right way to do it.
Jodyone
x 3
vborovic wrote:Really, how do you know that? ... :D
My girlfriend still occasionally wonders where the turkey baster has gone from the kitchen :oops: Must buy another one
x 1996
good 2nd hand supply in Brighton...... #-o #-o #-o
Jodyone
x 3
You just had to go there, didn't you..? :-D :vomit1:
x 1996
Jodyone wrote:You just had to go there, didn't you..? :-D :vomit1:
I only go there at weekends, I call myself Suzzie
