I drive a C5. Symptoms are that when driving the car started to judder and the clutch pedal locked up (cannot press it in). Also the accelerator pedal is very slack and not like it normally is. Any help appreciated.
This is a 2002 model, 2.2 diesel, 108,000, manual
C5 Clutch & accelerator pedal
MarkC5
- x 3296
Re: C5 Clutch & accelerator pedal
If you can also post up the age of the car and the engine type, those with far more knowledge than I will have a starting point to work from.
VertVega
- x 13
I hope it is not the clutch bearing
As Hell Razor5543 mentioned, you should give more information about the car.
Year, engine, milage, man/auto and etc. would help alot.
