Where is air intake temperature sensor placed on the 2.2 hdi, 2001 year?
Lexia shows 28 degrees intake temp., but outside temp is 10 degrees Celsius grade.
2.2 hdi air intake temp. sensor
- x 5672
Re: 2.2 hdi air intake temp. sensor
Somebody shoot me down in flames if this is wrong but I'm sure it is the little green bead (thermistor) in the MAF sensor.
Lighty
- x 34
It is in the Airflowmeter
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
pavlebo
Yes, it is in airflow meter. But problem was in connector's pins, solved with contact spray. Thanks.
