Hydraulic pressure regulator - refurb of seals
KennyW
x 165
Unread post by KennyW »
Hi All,
Seal kit for regulator purchsed what do i look out for when refurbishing regulator :?:
What should I look out for :?:
Kenny
C3 1.4 petrol (SWMBO)
Mandrake
x 695
Re: Hydraulic pressure regulator - refurb of seals
Unread post by Mandrake »
A very large and powerful spring!
Citrojim can advise but I believe you need a rather large bench vice to safely disassemble it by carefully unwinding the tension of the spring.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 94
Unread post by citronut »
i used my valve spring compressor ( http://tinyurl.com/m6w7cof" onclick="window.open(this.href);return false; ) clamped in my vice to compress the end cap/bung so i could remove the snap ring/circlip,
i placed a small square steel plate ( around 2" X 2" square ) across the sphere opening and a long 7mm ( 11mm spanner size ) bolt in the tail/bung end were the tail end mounting bolt fits,
then clamp/compress the hole thing in my spring compressor
Regards, malcolm.
x 94
Mandrake wrote:A very large and powerful spring!
naah it aint that powerful Simon, its just like a valve spring but a bit larger in diameter :yikes: :-D :wink:
Regards, malcolm.
kenhall1202
Unread post by kenhall1202 »
Marc on club-xm posted a useful write up here: http://www.club-xm.co.uk/forum/viewtopi ... =13&t=3544" onclick="window.open(this.href);return false;
Ken
Ken Hall
VertVega
x 13
Unread post by VertVega »
Good pics here and helpful thread on this subject:
Xantia front accumulator housing leak: http://www.frenchcarforum.co.uk/forum/v ... 0&start=30" onclick="window.open(this.href);return false;
x 94
kenhall1202 wrote:Marc on club-xm posted a useful write up here: http://www.club-xm.co.uk/forum/viewtopi ... =13&t=3544" onclick="window.open(this.href);return false;
Ken
Ken
your link only take one to the club XM login page
although i can login is as i am registered over there the OP of this thread might not be,
you need to got to the thread you are trying to link to, then copy and paste the thread location address
Regards, malcolm.
KennyW
x 165
Thanks for the replies
Kenny
kenhall1202
Ken
Ken
Hi Malcolm,
That is exactly what I did! Link works fine for me (as an already logged in member of club-xm).
Ken
Ken Hall
x 5675
Doesn't work for me (non-member)
kenhall1202
myglaren wrote:Doesn't work for me (non-member)
I think the answer is in the name: CLUB-XM - you gotta be in it to win it so to speak!
Ken
Ken Hall
x 94
ok so it dont work as it does with copy and pasting links from here then
Regards, malcolm.
xantos
x 10
Unread post by xantos »
KennyW wrote: Seal kit for regulator purchsed what do i look out for when refurbishing regulator :?:
I'm interested which seals have you bought and from where (Citroen service or local supplier of seals)?
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
KennyW
x 165
Phone Martin @ Pleiades and he'll sort you out with a kit.
Just got mine and will be starting soon.
Kenny
xantos
x 10
KennyW wrote:Phone Martin @ Pleiades and he'll sort you out with a kit.
Kenny
I'm from Slovenia, so that doesn't work for me :roll:
