Just recently bought a 1995 405 turbo diesel estate, all working fine except the climate control is playing up. When I set the recirculation switch to fresh air it sounds like the motor doesn't stop when the flap is fully open, there's a clicking noise that I assume is the gears being eaten away. I took the pollen filter out to check and sure enough the flap opens ok. Does anyone know which part of the system is faulty? I've bought a Haynes manual but as you all probably know that hasn't helped one little bit.
cheers
Bob
