Most models have options for bigger wheels/tyres to be fitted either at the factory or later.
My question is, as a different rolling diameter will affect the speed calculation, can the wheel/tyre sizes be changed via Lexia?
Rob
Changing wheel/tyre sizes
hamster99
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
Deano24v
Re: Changing wheel/tyre sizes
whilst its true that the wheel size goes up, you should find that the tyre size comes down relative to it so that the rolling radius isnt really affected and if it is the changes arent that great.
a 225/55/17 will turn 754 times in a mile wheras a 245/40/19 will turn 755 times. or at 60 mph on the standard 225/55/17 you would be doing 59.9 mph on the 245/40/19. not really enough to make a difference. changing the tyre sizes though will make a difference.
-2008 Exlusive 2.2 HDi 173 Tourer-
hattershaun
- x 4
Yes, Lexia has the functionality to change wheel size setting in the car's computer.
I've seen this done on a 2009 C5 Tourer when the owner swapped from 18" to 17" wheels.
I think the information is used by the ESP and ABS systems and maybe the hydractive suspension ECU too.
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
SM 3.0 - 1972
DS 23 Pallas - 1975
- x 1996
Never knew that.....
Maybe if I leave the 17's on the car BUT change them in the Lexia to 19inch low profile I can have a "virtual" bad ride without the expense
Richard_C
- (Donor 2026)
- x 232
There is as a handy calculator here:
http://www.wheelcalc.com" onclick="window.open(this.href);return false;
Richard_C
