C5 Sat Nav 2004 to 2008 replacement
This section is for General Enquiries or for Systems not Covered Above
lakanooky2
Unread post by lakanooky2 »
Im Looking at getting a C5 Estate Exclusive. 16 valve 2004 to 2008
And i have noticed some come with Sat Nav and a bigger screen,I Have replaced the head unit on my hatchback for an Alpine no problems.(small screen)
If i buy/use the stalk adapter what will i lose out on
Thanks Mark
Thanks In Advance Mark
1999 Xantia 2.0 HDI SX Blue ...... Scrapyard in the sky
2003 C5 2.0 8v HDI VTR Green with Leather
2004 C5 2.0 8V HDI Exclusive Estate Red with Leather
2004 C5 2.0 16v HDI VTR Hatchback Red
2005 C5 2.0 16V HDI VTR Estate Black with Leather
x 2006
Re: C5 Sat Nav 2004 to 2008 replacement
Unread post by Stickyfinger »
lakanooky2 wrote:Im Looking at getting a C5 Estate Exclusive. 16 valve 2004 to 2008
Thanks Mark
If you wish to use the top of the dash to fit a screen (aka Sat Nav original fitting) then you will need a new dash or have to cut a lot...it looks like a swap job for the larger "cover" but it is not.
The fitted RD unit is not double din and is very low for a Sat Nav screen....maybe a pop out/up screen in the top 2/3rds and a 1/2 din pop out cup holder below (like AUDI). A pop-out/up screen will block the center vents however
You will loose controls (matched on the stalks) for the cars setting via the Radio front panel.
(Keep the original so you can reinstate the controls if needed, like a comms unit failure on the steering wheel (not uncommon)
lakanooky2
Im trying to find out what will i lose. Im thinking of installing a Alpine head unit instead of the RD sat nav unit. I have the stalk adapter and it works with the little orange display in my Hatchback at the moment.The exclusive estate i'm thinking of getting has the sat nav as standard. So if i replace the RD with the Alpine and keep the big display what will i lose ie what will not display.
x 2006
yes....blank I belive
x 2006
UpGrade kit for no sat nav cars...
http://www.navinc.nl/C52010-201-?s=2130" onclick="window.open(this.href);return false;
They claim this...
vborovic
Locked user account
x 40
Unread post by vborovic »
Yes, but the car in question is a 2nd gen C5, not the third one ...
lakanooky2
Yes mine is a 54 plate so 2004 to 2008
lakanooky2
Anyone shed some light on this matter please ?
hamster99
Unread post by hamster99 »
The larger satnav screen is used for much more than just satnav. It displays lots of warnings and also the various graphics for the front and rear parking sensors fitted in exclusives.
I think if you change the radio unit the screen will stop working completely.
Is there some reason why you'd want to change it?
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
lakanooky2
I need to change the headunit as the original one will not cut it.The reason is, i enter sound competitions and an after market ie Alpine H/U gives me so much more.I have the MK 2 VTR and have fitted one to this and still keeping the little orange display ie mpg, trip, can go into the menu and turn off/on everything.The estate i'm thinking of getting has the sat nav big display as standard. So if i replace the RD sat nav with the Alpine, and keep the big display what will i lose ie what will not display.
hamster99
Well, for starters you will lose all sat nav stuff as the sattnav needs the map disc permanently in the single CD slot to work. One of the reasons why exclusives with sattnav have a CD multi changer under the drivers seat.
As for other stuff, it might be that you will have to try it and see as I doubt you will find anyone who has done exactly what you are thinking of.
Vborovic might have some tips as he has done a lot of sat nav and ICE stuff although I think he has a newer X7 variant.
x 2006
As said, it cannot be done without loosing the screen display. The 200-2006 SatNav is crud now anyway....no post code searches etc.
The only way is to rip it all out and use the space in the dash for another screen/system....you then loose all controls except from the stalk buttons.
Edit:...You could try modding the Aux inputs by increasing input levels (need a small line increase amp which is available) and add in a speaker side amp. Add a remote Bluetooth and run a MP3 player off that as a direct feed to the Aux line.Change speakers.
vborovic
Locked user account
x 40
Sorry, I'd like to help out, but I never did sat nav equipment on the earlier C5 models (prior to 2008)
Tvermoes
Unread post by Tvermoes »
This is exactly what I am looking for!
I can't find that on the site you are linking to..... Please help
Stickyfinger wrote:UpGrade kit for no sat nav cars...
They claim this...
x 6950
Ok - Here's another site that is UK based offering a similar system for the C5 - Never used them as I have the NG4 Navidrive 3d already in my X7 - but I would suggest you speak to the guy regarding their Head Unit and will it allow you to access the car menus / settings / configuration that is currently controlled by the exiting Head Unit. :-D Not cheap, but a LOT cheaper than trying to retrofit an NG4 system (if possible, given the additional kit with it).
http://autogpsdvds.com/index.php?route= ... uct_id=390
