I have a Xantia 1.9 TD 1996.
Can anyone post the pin connections for the plug on the airbag control unit in the centre console, and in particular the 2 leads to the steering airbag?
Phil
Xantia Airbag control unit
- x 1481
Re: Xantia Airbag control unit
In the absence of a Xantia diagram, you can find an XM diagram here, the airbag ECU connections should be the same but other wiring and connector details will differ.
exect
Thank you for your help.
Regards
Phil
Regards
Phil
