C3 Sensodrive Gearbox ECU Waterproofing
Citroen154
Unread post by Citroen154 »
Does anyone know if there is a waterproof cover available for the Sensodrive Gearbox ECU please ?
It is in a very low position on the end of the gearbox and very susceptible to water ingress, as I have just found to my cost - Does it need to be mounted so low and actually on the gearbox ? It is basically just sending electrical signals to the gearbox selector unit and clutch actuator unit, so why does it need to be mounted in that position ?
lexi
x 133
Re: C3 Sensodrive Gearbox ECU Waterproofing
Unread post by lexi »
You could make your own. Not standard Denso tape as I mentioned though. There is a fireproof version, but not freely available. I have sealed the joints in my ecu boxes with black RTV sealant. The are at the rear of car under the floor.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
