indicator stalk on 1998 series 2 Xantia
DublinChris
Unread post by DublinChris »
Ok so while other things are working well I have an issue with the indicator stalk in that when I push it up to make a right turn sometimes it does not make contact and indicator does not come on - also sometimes when on it will drop out. This is proving an issue for our NCT (MOT) people. I don't have a problem with it because a light tap upwards and it stays on - it doesn't do it all the time but the tester picked up on it and is looking for a repair. Question is - is there a quick fix that does not involve trying to source and fit new part? would the parts still be available? Also they indicated on visual inspection that the rear offside brake line is showing signs of advanced corrosion. This seems to be a spring like pipe. Is this a common issue with a car of this age - 1998? I am told it can be a time consuming job to replace.
Let the good times roll
current every day 1998 Xantia turbo diesel 1905cc series 2
x 3296
Re: indicator stalk on 1998 series 2 Xantia
The following post probably will help. What happens is that the grease ages, and the copper tarnishes, so you then have a contact issue. I have had this happen, stripped, cleaned and polished the bits, and now I have a fully functional, reliable indicator stalk;
http://www.frenchcarforum.co.uk/forum/v ... 22&t=49528" onclick="window.open(this.href);return false;
DublinChris
Hi James many thanks for that hopefully that will be a result for me 8-)
x 3296
I bet that, when the indicator glitches you get a much more rapid 'ticking'. This is a known fault, and cleaning the indicator worked for me (and others).
DublinChris
Hell Razor5543 wrote:I bet that, when the indicator glitches you get a much more rapid 'ticking'. This is a known fault, and cleaning the indicator worked for me (and others).
Yes you are right when it glitches I get the rapid ticking :)
Xantidote
x 4
Unread post by Xantidote »
On my S1, cleaning it up gave me another year of use, then it played up again, so gave up & fitted new switch
Martin
1995 Xantia TDLX (deceased :( )
Jaf
x 42
Unread post by Jaf »
Mine went too. Very easy to replace, at least on S2 cars. New one' s been working several years now. Did not like the fizzy sound!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
spider
x 77
Unread post by spider »
Not an uncommon problem, 306's used to have this a fair bit as well, not surprising as its the same switch really.
Andy.
