boxer U1600 fault code and gear change very tight
x 94
Unread post by citronut »
two separate problems on this wagon
it sometimes will not start, i plugged my DIS-LEXIA/PLANET up it and it comes up with fault code U1600, do i just run it through the key reprogram section,
the other thing is the gear selector is very very tight, question is can the cables be rejuvenated/freed off
Regards, malcolm.
