ok
is it possible to program/re program a second hand MK1 C5 plip to a different car ????
is it possible ??? on a MK1 C5 plip
- x 94
Regards, malcolm.
- x 1485
Re: is it possible ??? on a MK1 C5 plip
Basically no....the chip is a write-once only affair (the car actually writes the code to the key). So, you would need to get a new chip and a new blade to make it work. Not sure where the chip is in the C5 key - might be in the blade?
- x 3304
Ben82 did a comprehensive write up on this, and came to the same conclusion.
- x 94
thanks for your replies but it not the immobiliser code but just the central locking/RFside of things
Regards, malcolm.
- x 1485
Ah, in that case, should be yes. As long as the plip is paired with a working key, then you just switch on and press the lock button on the plip.
