Parking brake fault after changing disks/pads
osx
- x 15
Had disks and pads changed yesterday and while driving back got a parking brake fault following with all the other lights ESP, ABS etc and SERVICE. Didn't notice any difference while driving. Stopped, turned engine off, restarted and only SERVICE light which went off after I drove away. Happened once more just before reaching my destination. Could it be something to do with the new disks/pads? The OBDII scanner does not come up with any errors.
C5 X7 Exclusive 2.0 HDi Auto
- x 1480
Re: Parking brake fault after changing disks/pads
It could be related, or it couldn't....
Brake light switch or underbonnet fuse box are candidates for this fault - isn't this the one you're having trouble with the gear selector not unlocking too....? Likely linked - Lexia session required!
osx
- x 15
Also anti-rolling back error with all the others. Started again this morning, no errors. Drove for 10 min and then got the same - after breaking a bit harder maybe? Will see if the dealers warranty is worth it's money
osx
- x 15
Different one this timeRichardW wrote:It could be related, or it couldn't....Brake light switch or underbonnet fuse box are candidates for this fault - isn't this the one you're having trouble with the gear selector not unlocking too....? Likely linked - Lexia session required!
This is a manual.
What should I check in the fuse box?
osx
- x 15
Anyone with a Lexia around the area by any chance?
- x 1987
Yep, BA4 4LLosx wrote:Anyone with a Lexia around the area by any chance?
osx
- x 15
Great!! Don't suppose you are free today? Send you a PM
- x 1987
Pop down, as early as poss
osx
- x 15
After 150 miles it popped up again while I was slowing down behind a lorry on the motorway doing 15-20mph. I am sure it will be fine tomorrow but don't understand what is causing it.
- x 1987
Personally I would be back to the place that did the work PDQ with any brake problem.
- x 1480
Lexia....no other choice! We can speculate till the wheels fall off, but the only way to know for sure is to ask the computer what it is upset about!!
