Where to buy a siemens maf at the best price?
SwissSPEC
Unread post by SwissSPEC »
I'm trying to look online to find the cheapest priced genuine Siemens maf to fit my C5 2Litre hdi 8valve estate 110bhp on a 2002 plate.
I've found eurocarparts will sell me one for £83.94 gulp, does anyone know of any other places which are cheaper?
It must be a genuine maf rather than the chinese cheap rubbish found on e-bay etc....how do i know this :(
Many thanks.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
x 1995
Re: Where to buy a siemens maf at the best price?
Unread post by Stickyfinger »
SwissSPEC wrote:I'm trying to look online to find the cheapest priced genuine Siemens maf to fit my C5 2Litre hdi 8valve estate 110bhp on a 2002 plate.
Many thanks.
Looks like a good price for a VDO original....
Maybe 2nd hand ?, its worth it if you get a good one.
Alandt
New User
Unread post by Alandt »
I have just fitted an ebay maf to my C5 2.0 HDI Estate and all seems good so far - no more anti=pollution fault warning and no limp mode!
Jeff
Unread post by Jeff »
I tried an ebay one (£30) which lasted a few months....then went to a scrapyard and and got the original part (£10.00) ......that was about 1 year ago..... I'd rather an old original part than an ebay copy
Currently driving Citroen c5 2.0 HDI 51 Plate
x 5672
The pattern parts have a dreadful reputation. VDO (formerly Siemens) is definitely the one to go for.
SwissSPEC
Thats annoying if you thought that price was good :(
Bx Gti 16v
BX TZD Turbo - Sorn
SwissSPEC
Is there anyway on a lexia or equivalent to test whether the maf is working correctly or not? Does anyone know what the paremeter values a correctly working one should show? I don't want to change the maf if there isn't anything actually wrong with my cheapy.
Bx Gti 16v
BX TZD Turbo - Sorn
osx
(Donor 2022)
x 15
Unread post by osx »
If you disconnect it and you are still in limp mode then the MAF is not the problem.
C5 X7 Exclusive 2.0 HDi Auto
SwissSPEC
Hi osx, sorry i don't get what you mean, the car appears to be working fine, so removing the maf to cause a fault isn't going to tell me anything?
Bx Gti 16v
BX TZD Turbo - Sorn
x 1490
If you get it on a Lexia you can see the air flow. 400 is about the right figure at idle for a 2.0 HDi - it should rise smoothly with revs. If you disconnect the EGR valve the flow should jump up.
SwissSPEC
Just got to find someone with a lexia. Cheers for the info RichardW :)
Bx Gti 16v
BX TZD Turbo - Sorn
SwissSPEC
Does anyone know the correct siemens vdo maf sensor number that i need for a 2002 c5 2.0hdi 8 valve 110bhp engine? I've tried searching for the info & can't find out exactly which one it is, i found one for the 107bhp version of the same engine, but not the one i need??
Bx Gti 16v
BX TZD Turbo - Sorn
