Need Xantia phase2 wiring Circuits
Houtan
I need Xantia Exclusive wiring Circuits, anyone have them on PDf file or have link for download?
Carsten S
Re: Need Xantia phase2 wiring Circuits
I can pick out specific diagrams - What do you need?
It will take me a month, to get all the original diagrams out.
- x 8313
I have a few available immediately upon request. As said, tell us what you need.
Anything not immediately available can be made so in a day or so...
CitroenCrazy
- x 65
Hi guys
Just picking up on this thread, does anyone have a wiring diagram that covers the Eberspacher heater ?
Having fixed one in the past by replacing the glow plug (thanks for the write up in the Citroenian, Jim!), I had high hopes of effecting the same repair on a second car at the weekend.
Sadly, on checking, the glow plug was hunky dory, so the quest for a fix continues.
Andrew
Andrew
- x 8313
Hi Andrew, I think I do.. I'll look it out later but I'll expect you'll find the Erberspacher is suffering from the other stock fault: seized or very tight fan motor bearings...
Does it try to fire up at all even with the relay bypassed?
CitroenCrazy
- x 65
Hi Jim
Thanks, I checked the fan, it seems to spin freely. Haven't got around to trying the relay bypass yet.
Andrew
Andrew
- x 8313
That's a good start Andrew..
Reminds me, I've not yet looked for the diagrams
I'll try to this evening...
