engine knocking 2lt hdi
colin machin
c5 (2002) hdi it has a bad rattle from the cam belt area i have taken the drive belt off and run the engine and the rattle as gone ,the power steering pump felt rough so i changed it i put the belt back on and the rattle as come back it sounds like its coming from the front pulley the pulley looks ok any ideas welcome thanks .
C5 2007 HDI
THELABMAN
Re: engine knocking 2lt hdi
The pulley is similar to a DMF with a sandwich interior between two steel outer and us breaking down you'll need to replace the pulley with a new one ...Petef
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
- x 1240
Shine a light on it with the engine running and you may well see its running out of line - its a common fault.
colin machin
hi took the crank pulley off and it looks and feels ok i took it to the parts shop and he said it looks ok to him the ones he has seen where shot . any way got to start some where so i brought one £45 pounds ,fitted it and its done the job .thank for your input .looking at the old one it looks perfect .
C5 2007 HDI
