Had this van a few weeks now
Fixed leaking sump changed oil and filter
Changed gearbox oil
Changed crank pulley believing it was the culprit after
Removing belt and listening
This is a new gates pulley
I have a slow tick tick noise from the off side and I've run out of ideas?
I also have a driveshaft oil leak
Does the driveshaft pull from the box easily
Or is it more involved?
Feeling suicidal
nemo tick tick
Lighty
- x 35
Re: nemo tick tick
Driveshaft does come out of the box easily, keep,it topped up, these have a habit of running dry.
Don't suppose your ick is an injector leak ?
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 1240
Re: nemo tick tick
Does the tick vary with engine speed or road speed? If its slower than engine speed but synchronised with it I would suspect the belt, does it still do it with the belt off?
stevemiller
Re: nemo tick tick
Thanks for the replies
It makes the noise with the belt off
I only noticed it at idle, but this is probably due to roadworks noise etc
It appears to be coming from under the wheel arch
- x 1240
Re: nemo tick tick
The only thing that I can think of that will give you a 'tick' slower than engine speed but coupled to it is the cam belt, I would think one tick every 4-6 revolutions of the crankshaft would be about right. If you can get the top part of the cover off you can watch it go round, if you put a white mark on it and the tick is occurring at the same rate as the white mark passes you, that's what it will be.
stevemiller
Re: nemo tick tick
Thanks the tick happens around every two seconds
Im not sure I understand pete
The cambelt turning on the cam pulley, wouldnt some cogs turn more than others
I apolagise its late
stevemiller
Re: nemo tick tick
I have another problem I changed the gearbox oil a few weeks ago and now the driveshaft oil seals leaking
im wondering if the seller put an additive in to stop a leak and the box had previously run low
and damaged itself
I found a dry stain when I refilled
the vans one problem after another and im a bit peeved off lol
I ran the van without a belt and the electric motor sound on decelerating appeared to stop
the pulleys all seemed fine, apart from a bit of ware on the power steering but not enough I felt
I changed it anyway along with the alternator pulley with a new belt
also the crank pulley as initially this is where I thought the noise was coming from
arrhh
and damaged itself
arrhh
stevemiller
Re: nemo tick tick
I think I understand if the belts snagging somewhere a tippex mark on the belt will highlight this.?
- x 1240
Re: nemo tick tick
I am dividing the total length of the belt by the length round the crankshaft pulley but I think 2 secs is far to long for it to be the belt rotation. I have no idea what that could be, if it was me I probably wouldn't worry about it unless it got a lot worse.
