Wife's C3 VTR power steering is making some very strange noises. It's like a sort of intermittent growling noise which stops when you aren't turning the steering wheel.
On a traditional system I would suspect low hydraulic fluid or some contamination but on this the power steering is electric, with everything built into the rack and controlled by an ECU behind the battery fuse box.
Apart from the noise the steering works fine, although I did think it felt a little heavier than usual. I hope it doesn't need a new rack as it looks like a pig of a job (drop exhaust, undo subframe etc).
Any thoughts?
Rob
C3 Power Steering Problem
hamster99
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
- x 1499
Re: C3 Power Steering Problem
If it only occurs as you are turning the wheel, then can't see it can be anything but the rack - worth a check though that it's not the strut top bearings (turn the steering lock to lock with it jacked up to look for juddering as they turn). Can't get a price from service.citroen, but anecdotal evidence suggests it's £lots
bba-reman appear to do refurbed racks, so it can't be an all that irregular failure.
