Now my brake pedal is hissing!
smoker
Unread post by smoker »
Noticed recently that the brakes are not holding a servo vacuum after turning of the engine, but today there was a noticeable hissing sound inside the car after releasing the brake pedal. I'm fearing that this is the servo unit, and from the looks of it most of the car has to be dismantled to get at it.
Anyone had any experience of servo issues on a Xsara - could it (please) be a simple, cheap part to replace?
Thx all
52 reg Xsara 110 hdi
dnsey
x 19
Re: Now my brake pedal is hissing!
Unread post by dnsey »
To check the servo, with the engine stopped, put your foot firmly on the pedal. Now start the engine. If the pedal moves further, the servo is working, at least to some extent.
x 94
Unread post by citronut »
as dnsey says, although if the engine has just been run you should pump the pedal 2 or 3 times to expel any pressure, then as dnsey said
Regards, malcolm.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
If theres a continious hissing when running the Servo is goosed!
Had this on a 306, instant MOT fail, so I fitted one from a L reg 306 to a R reg 306, all was well again. Not quite as hard as I expected it to be.
A very sad...
1994 XM 2.1 d auto
