Hi
What is the procedure to detach the fuse box that is located under the hood
Xantis - detachng the fuse box under the hood
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
citroenxm
- Fallen Hero
- x 70
Re: Xantis - detachng the fuse box under the hood
Remove the two purple relays at the side of it.. twist and push down the relay holders.. pull out the relay retainers
slide the fuse box off the two spigots it sits on.
then on the side of the box you will see two yellow bits.. pull on them carefully.. these are lockers to hold the plugs in the bottom of the fuse box in place..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Oh unbolt the main feed cables with a 10mm on the end of the fuse box..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
