c4GP fuse box newer type
c4guy
Unread post by c4guy »
Does the newer type of fuse box give same problems as older more expensive type?
Thank you.
x 1499
Re: c4GP fuse box newer type
No idea... There's not many C4GP on here (mine and yours now by the looks of it.... :-D ). Having said that, ours (2008 1.6 HDi) is giving trouble with the fuse box I believe (handbrake / ESP stops working). I speculated about whether the later board could be fitted, but shied away from doing it (thread) - I have got a 2nd hand one to fit - was going to do it today, but car now covered in 2" of snow... :roll: What age is yours / have you fitted the later board? TBH I doubt this is causing your current problems - change the fuel filter and see where you go - if the pressure regulation fault is still there, then you may need to change the regulator - bit of a trial I imagine on a C4GP #-o
