C4 GP anti pollution fault?
c4guy
Unread post by c4guy »
1.6hdi
Fault codes:
All Codes cleared then these are theree after the eml came on
Rac code reader:
P0088
P1161
P0088
Lexia guy
D208
0088
0488
1161
7157
1351
I have newer fusebox
Fan belt and pulley just replaced
Oil service with that low soot oil just done.
Fuel filter not yet replaced this service.
First time Anti pollution fault yestetday and car stalled. Then limp mode on immediate restart, then next restart eml off and back to normal
So many codes, they were just cleared to wait to see new ones.
Today trying to get dpf regen to start, car at >3k rpm, antipolution warning, eml light came on, car did not stall, but went into limp mode immediately.
All help gratefully received.
Thank you.
x 1432
Re: C4 GP anti pollution fault?
Hi
I'd change the fuel filter, and see where that gets you. The fault "Temporary fault Fuel high pressure regulation Pump regulation electrovalve opens more than the setting" is probably the one causing limp mode. Could also be the throttle playing up, but see what happens with a new fuel filter.
c4guy
Thanks, any idea about the other post of mine about the reheater in the fuel filter?
Sl4yer
Unread post by Sl4yer »
Had the glow plug fault showing on our C3. All plugs were replaced, and it's never come back. But never suffered any starting issues either.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
