Hi I have a 2002 Phase 1 Berlingo with a knackered speedo, if I replace it will it show the mileage on the car ie 87000 or will it show the mileage on the replacement speedo?
Many thanks
Mark
Berlingo Speedo
addo
- Sara Watson's Stalker
- x 95
- x 1056
Re: Berlingo Speedo
Depends on if its multiplexed or not. The op has said its a phase 1 on a 2002 model ? Would have thought a 2002 model would be a ph2 ? Typo somewhere ?
All ph2 & ph3 models are multiplexed, only some later ph1 models are multiplexed. Non multiplexed models will display the milage thats stored in the speedo head. Multiplexed models will behave as said above.
- x 94
Re: Berlingo Speedo
what actually wrong with the original speedo, as it could be the transducer at the gear box that is faulty,
Regards, malcolm.
ds21h
- x 3
Re: Berlingo Speedo
Hi it is a 52 plate but last of the phase 1 Multispace models.
The speedo does not work, how would I tell if it is multiplexed?
Regards
Mark
Regards
Mark
- x 94
Re: Berlingo Speedo
as i said in your other thread send me the last 8 digits of your chassis/VIN No.,
i do know my friends 05 307 is partial multiplex, and i believe this was the change over year'ish to full multiplex
Regards, malcolm.
ds21h
- x 3
Re: Berlingo Speedo
Hi Malcolm, last 8 digits for the chassis are 65868947
Many thanks
mark
Many thanks
mark
addo
- x 95
sparksie
- x 33
Re: Berlingo Speedo
Hi
Far more likely this will be the sender, or its' wiring.
Easier fix than a new instrument panel and cheaper from the breakers, too.
Sparksie
2000 Xantia 1.9TurboD
- x 94
Re: Berlingo Speedo
i have got a transponder working again a few years ago, this particular one had filled with gear oil as its spindle seal/O ring had failed,
i took it apart cleaned it oooot, put it back together and bongo it worked
Regards, malcolm.
- x 1480
Re: Berlingo Speedo
If it's the transponder, then neither the odo nor the speedo will work. If it's the speedo head, then the odo continues to count. Normally
