Comm 2000 Peugeot 406
johnway
Unread post by johnway »
Hi everyone,
Diagnostic check has revealed my airbag fault lies with tag 2 open circuit on the comm 2000 unit. Now as it is also suffering from indicator problems I feel the time is right to replace the unit with either a reconditioned or brand new part. My question is this : would a replacement part have to be programmed to my car ? A supplier is telling me that his supplied unit would be pre-programmed and calibrated for my car, thus saving main dealer costs. I am a bit bemused by this, having had parts installed in the car before any programming etc. was necessary for them to work. Any advice greatly appreciated.
All the best,
John.
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
x 3296
Re: Comm 2000 Peugeot 406
There is a guy in Bradford who repairs the units. He has a fast turn around time. Ask citronut, as he has recently (this month) used him.
johnway
Many thanks James !!
x 1492
John
Com2000 fitting only requires calibration if the car is fitted with ESP - you need to re-calibrate the steering angle sensor. If it doesn't then the COM2000 is plug and play. Note, I suspect that even if you have yours repaired, and you have ESP, then it may need re-calibration when it comes back. There are people on here with Lexia / Pug Planet that can probably do it if there is someone nearby to you http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
johnway
Thanks Richard. Excuse my ignorance on the subject but how would I know if my car is fitted with ESP or not? It is an Executive model with a lot of "toys" etc. but I have not come across this acronym before.
Many thanks,
John.
x 3296
Normally a car fitted with an 'Electronic Stability Program' has a button to switch it off (by default it is on). I have seen this denoted with ESP or a icon of a car with wavy lines.
johnway
OK - thanks James. I have not seen any such button on my car.
All the best,
John.
x 3296
Peugeot may call the ESP program by a different name; the initials ASR seem to be used. I just did a search for Peugeot 406 2002 Exclusive, and ASR was mentioned as part of the toys.
x 94
Unread post by citronut »
here is Greame Halls ebay listing link
http://tinyurl.com/ntt4296" onclick="window.open(this.href);return false;
he is very very helpful,
he has even offered to have the one he just sorted the indicating/head lamp fault out on, the have it back to sort the no fog light fault for FREE,
as he nor i or the owner were not aware this fault existed, till i re/fitted it to the car and checked through all its functions,
very fast turn around though, we sent it off to him Royal mail guaranteed next day delivery, on him receiving it he repaired it and sent it straight back out the very same day, i had it back around 11 am'ish on the third day,
he also has a very good phone back up support, and will go through any questions step by step,
maybe we ( Stevey baby :-D :wink: ) can stick the link in the super stickies pages
Regards, malcolm.
x 94
johnway wrote: how would I know if my car is fitted with ESP or not?
Many thanks,
John.
if you send me the last 8 digits of your chassis/VIN No. i can send you your cars birth certificate, this has everything it left the factory wearing plus lots more
Regards, malcolm.
johnway
Hi Malcolm,
Many thanks for your help - greatly appreciated !! Chassis/Vin VF3**************[VIN obfuscated, can be read by forum staff] 81558154
Regards,
John.
x 1492
citronut wrote:here is Greame Halls ebay listing link
'Tis done http://www.frenchcarforum.co.uk/forum/v ... 19&t=50388" onclick="window.open(this.href);return false; not sure how to make it sticky though.... :lol:
x 1492
service box says
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
So no ESP. Part number for the fitted COM2000 unit:
6242 C2
01
MULTI-FUNCTION CONTROL UNIT
