306 heater blower issues
Bandit12
x 12
Unread post by Bandit12 »
Hi Guys
A mate has just joined the French car fraternity and bought a y reg 306 1.4 GLX with aircon yesterday. A crackin little car but with one fault, the heater blower is intermittent. the previous owner said something about the circuit board having a crack in it but they werent sure and this diagnosis was handed over to them when they bought the car 18 months previously.
Is this a common or known fault?
Any suggestions on diagnosis and repair are appreciated.
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
x 8417
Re: 306 heater blower issues
Due to the high current consumed by the blower I'd be more inclined to look at the various connectors starting with the blower itself, those on the blower regulator module and right back to the ignition switch and finally the ignition switch itself...
On other PSA vehicles of the era, the ignition switch is often the culprit and on occasion the intermittency can be provoked by wiggling the key..
I'd have thought a crack in a PCB was unlikely...
evilally
x 3
Unread post by evilally »
They might have been referring to cracked solder joints on the control panel? I've seen this before. If a firm thump on the panel gets the motor going, then it could be this. Remove panel, examine joints with a magnifying glass for any cracks and reflow as necessary.
'97 406 1.9TD, 314k.
elma
x 284
Unread post by elma »
If you need any bits I have a scrap 306. You can have what you need for postage if its there.
Bandit12
x 12
Thanks guys and yes defo interested in some scrap parts. We did try giving the panel a bit of a thump but it made no difference. I think best plan is as you have suggested which is to remove and inspect.
I've sent this link to my mate so he can join the forum so either he or I will be in touch re any spares.
Bandit
Bandit12
x 12
An update, my mate has booked car in with a local french car garage on friday for a diagnosis. Ill post the findings and take up the very generous offer of spares over the weekend when we know the results.
Bandit
Bandit12
x 12
Ok the garage says the resistor has failed. Ordinarily a simple job and I've replaced several on my old fraud mundeo over the years but because this car has aircon it is part of the motor so both items have to be replaced as one complete unit. They have quoted £168 including VAT to do the job. Does this sound about right?
Bandit
