wondering if there are any options to replace steering wheel on 1998 series 2 Xantia - Turbo diesel? My wheel is now very worn around edges. I do not use radio controls as I have replaced the original unit. With the airbag are there any after market options or is it a case of trying to find an original from a breakers?
tried a search for steering wheel on forum but no results.
Steering wheel options
DublinChris
Let the good times roll
current every day 1998 Xantia turbo diesel 1905cc series 2
citroenxm
- Fallen Hero
- x 70
Re: Steering wheel options
My guess would be an original only... Ive a few, but unfortunally on them the Rim Trim twists freely on the metal frame on them, so useless really.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
elma
- x 287
Original only I'd say as well.
It is possible to change it completely and lose the airbag but probably not a great idea for a road car.
citroenxm
- Fallen Hero
- x 70
Air bags must work now, and im sure are part of MOTs now...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DublinChris
Airbag has to stay for our mot equivalent - if it was a standard fitting originally. So looks like only the original will work. Are other people having the same problem with worn wheels? Maybe there is a cover that can go over the wheel?
elma
- x 287
Definitely a bad idea on road cars then. There are some steering wheels on ebay starting at £25.
All plastic wheels seem to wear and go loose eventually. Leather ones I haven't had do it yet but I'm sure they go eventually.
citroenxm
- Fallen Hero
- x 70
Theres good n bad. Also, An S1 wheel will only go on an S1 and S2 on an S2 only.
I wonder what people do with their wheels, My Xantia at 283k - leather rimmed didnt look too bad at all, yet Ive seen some at 150k which look dreadfull..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Seem the covering twisting at the moment is confined to S2 wheels only. Im yet to ever see an S1 wheel covering twist on the rim...elma wrote:Definitely a bad idea on road cars then. There are some steering wheels on ebay starting at £25.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
elma
- x 287
Now you've mentioned it none of my Xantias have either, the only one I changed was my L reg because a friend had a spare Leather one. I've only had S1s. I could be wrong about ebay as well, didn't realise S1 and 2 were different.
DublinChris
My 1998 S2 does not have a leather wheel - only the hard vinyl? outer casing - which has worn away now in quite a few places - I am at 190K miles
- x 1987
These are good, thin and when you take your time (Heat the wheel and the leather first, scuff clean the original) with the stitching you get a very good result.
http://www.ebay.co.uk/itm/like/25136516 ... 0&ff14=108
