Hi
Can any one post or Email me the wiring diagrams of my car.
Thank
Xantia - Need wiring diagrams
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 1438
Re: Xantia - Need wiring diagrams
I don't have many Xantia mk2 diagrams, you might like to be more specific about which diagrams you need, there are a lot of them.
lancia58
- x 8
I need the diagram that shows the inside fuse box ( the one below the streering wheel ), and how the engine ECU is fed with 12V. See the following link that describes the problem I have
http://www.frenchcarforum.co.uk/forum/v ... =3&t=50336" onclick="window.open(this.href);return false;
Zohar
Zohar
xf1ref
- x 12
Zohar, if you have problems with the fuse box you have to dismantle like in the link below.
http://xantia.voila.net/boite_fusibles.htm" onclick="window.open(this.href);return false;
Some time ago I had problems with right front sidelight and I fixed it after I remade all the solderings.
Maybe your problem is a cold solder joint because this is affected by temperature.
lancia58
- x 8
Thanks - I'll follow the instructions and let you know
Zohar
Zohar
lancia58
- x 8
Hi
I see in your posts that you have electrical diagram of the Xantia. Can you post the electrical diagram of my car Xantia 2.0 16v SX automatic with air conditioner make year 2000
Zohar
Zohar
xf1ref
- x 12
I have a pdf file with electrical diagrams for xantia model up to 1998 and on but is not for a specific model.
In the link below I shared 3 pdf files for xantia including electrical diagrams.
https://www.dropbox.com/sh/k0abzimtb4wm ... GpXta?dl=0" onclick="window.open(this.href);return false;
lancia58
- x 8
Hi
