The following are Citroen catalog numbers of two different engine harnesses
652979 - Auto gearbox AL4 AND MOUNTING BOSCH SINCE RPO 08057 EXCEPT LPG + UNLEADED PETROL EXCEPT EEC 2000 DEPOLL (ENGINE) - MARKING 9635401580
652980 - EEC 2000 DEPOLL (ENGINE) SINCE RPO 08057 UNTIL RPO 08637 EXCEPT LPG + UNLEADED PETROL - MARKING 9635401680
I am looking for the pin out of the connector that is plugged onto the engine ECU for both harnesses
Zohar
Xantia - Need help for pinout of engine harness
- My Cars: Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD - x 8
Re: Need help for pinout of engine harness
Is it for the car in your signature?
can you confirm the actual engine code too?
maybe I or someone else can look in the workshop manual for the electrical diagram, i can see the ecu has pin numbers, but i need the actual engine
...from Dei
1999 Xantia 2.0 Hdi 110 Exclusive (8396)
2001 Xsara 2.0 Hdi 110 LX Auto
- My Cars: C6 2.7 HDI '06
C5 2.0 HDI Auto '06
Xantia ACTIVA 2.0 HDI '98
Xantia 1.9TD '94 - dead
Exactly! The harness is not important for your question. The engine ECU pinout is the same.
The ECU for the 652979 harness is 1929 LH
The ECU for the 652980 harness is 1929 VE
Zohar
Zohar
Re: Xantia - Need help for pinout of engine harness
Hi
Can any one help with this
