Changing Rear Tailgate Light Cluster on Xantia TD Estate
ecohouse1
x 3
Unread post by ecohouse1 »
Hi Folks
Stupidly reversed my TD estate into a wheelybin and broke my reversing Light Lens! Well hacked off as I should have checked it was there! :evil:
I see them on e-bay for £18 inc delivery. Are they easy to change? I presume I Have to take out the trim inside the door?
Cheers
Alan
KennyW
x 165
Re: Changing Rear Tailgate Light Cluster on Xantia TD Estate
Unread post by KennyW »
Allan,
Very easy to change which light cluster is it.
Open tailgate and depending which one remove cover, if it is cluster on rear wing unscrew wing type nut by hand and take off,remember to disconnect wiring and replace.
if tailgate remove cover then there is the plastic protection against moisture,unscrew offending cluster,disconnect wiring and replace. The BOL is accurate with its description and has photos.
Kenny
C3 1.4 petrol (SWMBO)
ecohouse1
x 3
Thanks, I take it this is the infamous plastic membrane that causes the pesky leaks if its not sealed up again properly? Does it peel away or is better to cut?
