This is really annoying me now!
PRV engine, the engine ran for a few moments, then stopped.... and hasnt ran again.
Checked the harness point to point!
Changed Coil
Changed Amp Module,
Leads ok
etc etc
The only thing I can think of is there is a Capacitor to earth connection by the coil. Could a dead capacitor stop it from sparking! Need to sort this, its taking toooooo much time up now...
NO SPARK! PRV SORTED!!
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 5672
Re: NO SPARK! PRV
Remove the cap Paul. It is only for RF interference suppression. If it has gone short circuit it will almost certainly prevent the engine from starting.
citroenxm
- Fallen Hero
- x 70
Re: NO SPARK! PRV
Ill try Steve, Thanks..
Im after ideas for the next time I go and visit...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
Re: NO SPARK! PRV
Paul
did you replace all the parts with new,
you probably know already that some rotor arms have a resistor between the tip and center buried in resin
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Re: NO SPARK! PRV
yea there was a 1000ohm resistance there malc
parts used were working the bloody car ran with them for about minute then stopped
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
Re: NO SPARK! PRV
maybe something has knocked the replacement module out then,
have you got something else you can test/double check each of the replacement bits on
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Re: NO SPARK! PRV
Yea another 24v xm but its 25 miles away at mums ..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Re: NO SPARK! PRV SORTED!!
Well yes, got this sorted! TWO things, A break in the harness, and more obvious in my face but didnt see it, there was strangely a SECOND earth lead on the Amp Module!
The normal earth was fine which I was looking at, but there was a second earth with a Ring terminal on it, and a small black flyer lead. I decided to just try and see what happens and hey presto the spark on the plug laying on the inlet was so bright it would light a dark room up!
Thanks for ALL sugestions, I thought I wasnt going mad, but onwards and progress to make now.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DHallworth
- x 167
