Hi ,
I have a 2005 Berlingo diesel van. The problem was that the fan was continually running fast and wouldnt stop.
I removed the blower and checked out the power transistors. One of them was faulty. I replaced the pair with equivalent new transistors. On re- assembling, the blower will not start up at all now. I was interested to see if I can find an electronic schematic of the ciruit board which contains the two transistors. I am unsure as to the signal values I should be seeing at the 4 pin power/control plug on the board??? It looks like the relay on the board is not energising and wanted to diagnose further to see if I cant find out if problem on circuit board or with the control signals going to it??? Any help much appreciated.
Many thanks
Berlingo 2005 heater blower electronic diagram
old-un77
Re: Berlingo 2005 heater blower electronic diagram
http://ramenmonster.com/logo/citroen-wiring-diagrams" onclick="window.open(this.href);return false;
is this any help?
is this any help?
