how to get diesel pump to work
curlykevs
hi all can anyone help how can i get the diesel pump to run wiring it from the ignition citroen relay 2.2 mk2 as cant get van to run after short circuit replaced blown fuse to ignition so now cranks but no diesel getting through any ideas as ive been out there all day having no luck dark now so back at it in the morning help needed thanks
macAU
Re: how to get diesel pump to work
Is there a fuse on the fuel pump circuit? If this is fused then no fuel will be delivered. Engine will turn over but will not fire!
1924 5CV 'la petit citron', 1970 Citroen DS21 Pallas, 1973 Citroen D Super 5
1981 Citroen CX 2400 Pallas C-matic, 1981 Citroen CX Reflex 'Familiale' 2400 ZF auto
1981 Citroen CX Super 'Familiale' 2400 C-matic, 2011 Citroen C5 and a 1991 Mazda E2200
