Water on front plug that goes in ecu
Baz2014
New User
Unread post by Baz2014 »
Ok, apologies if the terminology is incorrect here, but hopefully it'll make sense!
My C2 is getting water in one of the connectors that plug into the engine management system - of the three its the one nearest the front of the car.
Causing the car to cut out /low rev etc.
Its happened three times so far over the last few months. To get the car running again, I simply disconnect the plug, dry it out and I'm off again.
No matter what I do, I cannot see where the water is coming from, especially given that the battery cover also covers this part of the engine as well.
x 1055
Re: Water on front plug that goes in ecu
Unread post by wheeler »
Does it smell like engine coolant ? Unplug the engine coolant temperature sensor & check for the same in there. The sensors leak & the coolant can travel up the wire with the help of capillary action.
Baz2014
New User
Not much water on plug but enough to cause engine to cut out . Ain't smelt it . Water is around pins when blown away car works fine for week then water comes back . Water is defo not coming in from top cus all sealed at top so must be wiring or underneath the car ????
steve18gls
Unread post by steve18gls »
I would suggest that you cover the Ecu with a plastic bags mate or some other waterproof covering. Water near the Ecu plugs could cause it to fry the Ecu and that's a bill you don't want ! :)
