She broke the drivers door mirror herself
darbuck
- x 289
I think the bsi is going on my c5 its throwing up a different fault everyday today it broke the drivers door mirror by overheating it stuck my finger to it ouch and can't communicate with abs using lexia clone
Darren
- x 3298
Re: She broke the drivers door mirror herself
Seems like the battery might be on the way out. The C5 (and other C series Citroens) are very sensitive electronically, and if the battery begins to fail it can cause all sorts of weird random glitches. Get the battery checked (and, if need be and finances permit, replaced), and then go through the BSi reset routine;
http://www.frenchcarforum.co.uk/forum/v ... 11&t=40407" onclick="window.open(this.href);return false;
darbuck
- x 289
Oh OK thanks hell razor I'll give it a go in the morning and check back
Darren
old-un77
As an aside, on a Picasso Xsara, where is the Bsi located?, If a new one is purchased it needs programming from scratch, I presume? and will have zero miles on it?
thanks Bob
thanks Bob
Northern_Mike
It's mounted side on next to the fusebox near the drivers knee..
old-un77
thanks, Mike.
darbuck
- x 289
Done the reset procedure but still getting brake pads worn fault intermittently even though I completely disconnected sensors is there a connection any where under bonnet before it goes into cabin
Darren
