53 plate xsara picasso hor not working
x 94
Unread post by citronut »
i plugged my DIS-LEXIA up this car and in parameters is says "horn not activated"
there is a fault code of P1351
how do i reactivate the honker ?????
Regards, malcolm.
x 1996
missing n or w---e ?....makes a big diff ?
Unread post by Stickyfinger »
had too :)
Northern_Mike
Re: 53 plate xsara picasso hor not working
P1351 is related to the glow plugs Malcolm..
x 1489
Did you get it started Malcolm?
I suspect that what it is reporting is the status of the horn push on the steering wheel - if you press the button it should change to 'activated'. If it doesn't then the push or the COM2000 is suspect, if it does, and the horn still doesn't work, then either the BSI, the underbonnet fuse box, or the horn itself it faulty. Working out which.... :evil:
x 94
northern_mike wrote:P1351 is related to the glow plugs Malcolm..
yes Mike sorry got a little :? dont take a lot #-o
im sure i had the code for the horn not functioning on my phone but obviously not, all i have for the horn fault is
"PERMANENT FAULT
LIGHTING CONTROL INCOHERENCE"
apparently on taking this car to the MOT the horn did not work hence the failure, on its return to were the owner lives the horn worked again, on taking it to my workshop it does not work again
Regards, malcolm.
old-un77
Unread post by old-un77 »
perhaps a small dose of Via-gra?
