Has the HDI engine design been changed?
MarkandCath
The time has come to change our old faithful Dispatch. 287k DW8 engine is still going (I swear it is the fresh oil and filter every 6k that has helped it) but it and the van are now tired.
The old HDi engines had serious issues with seized injectors and black death caused by leaking injectors, you all know the score. My question is simply this, has anything been done to fix the injector related problems? I am happy to buy another new Dispatch but if the engine still has issues that haven't been addressed then I will look elsewhere.
So have Citroen redesigned the engine or is it still the same as it was?
citroenxm
- Fallen Hero
- x 70
Re: Has the HDI engine design been changed?
No you have had misleading information there Sir! The old hdi engine IS the best one to have...
The 2.0 8v HDi 110 IS the best hdi engine they ever did. Fitted to 406s and Xantias from 1998 to 2001 then Mk.1 C5s its the one to have!
They have the most reliable injector setup, useing a single Bolt and clamp setup, the shallowest injector depth, out them all...
The engine you are thinking of with injector problems is the 2.2 16v HDi engine fitted to the C5s from 2001 onwards! These engine are reknowned for sticky injectors...
Ive never failed to get an injector out of a 2,0 8v engine, and in 283k that mine did I only had one seal fail! And I know of a Taxi 406 on 300k and never had a seal, and a Xantia before that went to 286k without any injector seals!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
taffy
i read somewhere other day bout renault vauxhall peougoet vans havin a water seal problem on the bonnet letting water on to the engine and rusting injectors into the head!!! yea deffo 8v 2.0 hdi is the best engine mine had been in bout 200k and came out so easy(as long as u look after fuel/ service u might never have to
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
citroenxm
- Fallen Hero
- x 70
Renault vauxhall vans are not the same thing as Peugeot vans.. psa vans are shared with fiat..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
Though the 807 / c8 / ulysee car/van does also suffer the water on engines though on psa c8s it breaks the cam belt instead on 2.2 hdis ...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
taffy
yes i think it was watchdog jus couldn remember what van it was lol
looking at engines in the past to it makes me think.(weird thats rusty...)
worth a look under the hood of any car i guess
Northern_Mike
Watchdog was the Ford Focus Petrol filling the spark plug Wells with water...
taffy
hello mike how are you!!!???
jml
- Locked user account
- x 37
The specific problem of water ingress on these was solved by fitting a small plastic diverter. Later cars had a somewhat different arrangement I understand, thus avoiding the problem of water getting where it shouldn't.citroenxm wrote:Though the 807 / c8 / ulysee car/van does also suffer the water on engines though on psa c8s it breaks the cam belt instead on 2.2 hdis ...
However I don't know whether this was the sole cause of seized injectors or not.
Cheers
Julian Leyton (RIP) 2023
- x 1240
My experience with the early 8 valve Hdi is the same as Pauls, I have one in a 406 and another in a C5, the 406 has done 231,000 miles and the C5 200,000, they are both mostly original including the DMF and clutch, the only problem I have had has been the HP diesel regulator on the C5, I replaced that with a secondhand one off ebay, after a couple of tries, and its been fine since.
If I have to replace either of these cars it will hopefully be with the same again.
taffy
im slowly swaying to a c5...ive never liked them compared to a xantia but i hate to think wat problems im gona buy next
Northern_Mike
Buy mine Taffy. It needs new rear arm bearings at some point and the AC doesn't work. That's all that's wrong with it
I'd have a C5 110 HDi over a Xantia any day now, unless it was a V6 Xantia.as a toy. They are really very good cars for the money.
citroenxm
- Fallen Hero
- x 70
I disliked the c5 mk.1 with a passion originally. . However having a 51 plate hdi 8v 110 AUTO I now have little issues with them now. The autobox needs a lockup electro valve but other then that no issues..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Northern_Mike
As grumpy as ever, thanks for asking. I hope you and yours are well Taffy:)taffy wrote:hello mike how are you!!!???
jgra1
- (Donor 2021)
- x 36
going back to the original post, my feeling now is if I was to upgrade my 8v hdi, as the car is getting tired now.. I would go for the 16v 2.0 not the 1.6
its just a feeling
not based on much except odds and sods on here..
not sure when this engine was used up until, but sure its in new style Picassos and so on..
that would be my bet
John
its just a feeling
John
