Is the correct power steering fluid for a 2008 onwards C5 HDI 'central hydrolic fluid' ?
Just discovered the level is very low then discovered the posts on leaking racks on this year ??
C5 power steering fluid 2008 model
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Re: C5 power steering fluid 2008 model
You need to say whether you have a conventional sprung car or the Exclusive with Hydraulic suspension. The exclusive steering fluid is supplied by the suspension system I believe.
Rick.
2013 Citroen DS 5 D/Sport
Hi
It's a VTR+ so normal springs
- qprdude
- x 10
Can't help with that one, mines hydraulic. Try this.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48332" onclick="window.open(this.href);return false;
Rick.
