I thought it would be a doddle to tighten the handbrake on my wife's Xsara 1.9TD but after crawling underneath I couldn't find any adjuster.
Can someone save me the trouble & expense of buying a Haynes Manual just for this please?
Thanks in advance.
Handbrake Adjustment
Richard Gallagher
- x 1061
you have to remove the centre console,its quite easy remove ashtray,panel around cigar lighter,compartment above ashtray,unclip the plastic trim around the gearlever & the one around the brake lever.there are 6 T-20 screws around the ashtray area & another 2 at the back of the console on the sides,give the whole thing a good pull up at the back (it can be quite tight.once you have that off you may have to disconnect the round black multiplug to acess the adjuster (which is a 13mm nut)
- x 1506
ralph
bbrucez
jeremy
- x 3
The correct way to adjust the heandbrake is at the brake drum. The cable adjustment is only for initial setting up when fitting a cable.
Self adjusters do sieze and need to be overhauled regularily. Taking apart the adjuster screw mechanism, cleaning and re-greasing (just a touch) should restore operating efficiency.
Car must be taken to ensure that the back brakes are releasing fully. The ZX has a diagonal split braking circuits, so if one back brake overheats seriously and boils the fluid - a circuit fails. Both together . . .
Jeremy
Jeremy
bbrucez
