Hi lads
my 03 c5 keeps throwing up pad warning but new pads front and back and resoldered cables which keep breaking on the strut
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Brake pads worn
darbuck
- x 291
Re: Brake pads worn
Anyone any ideas by the way lexia not communicating with abs pump
Darren
- x 2941
Re: Brake pads worn
More often than not this is just a case of the wires shorting on the disk or the body somewhere. Check that they are properly located and not rubbing on anything.
darbuck
- x 291
darbuck
- x 291
Re: Brake pads worn
Tried that then disconnected and tied and taped up cables still no joy nct Wednesday can't access abs ecu
Darren
