Hi Folks,
The speedo on my 2001 DW8 powered Peugeot Partner doesn't work and hasn't since I bought it.
I have swapped the Speed sensor/transmitter for another one which I know definitely works, but when I tried it, it was still the same.
I haven't checked yet is the trip works when driven, I'll have to try that and if so, I'm guessing it's the actual speedo that's at fault.
Everything else on the dash works, including total mileage display within the speedo.
Any suggestions what else I need to check?
I recently had the o/s driveshaft out to replace the centre bearing and could see a white plastic collar below where the speed sensor/transmitter sits, inside the driveshaft housing. Is this what drives the speed transmitter drive gear?
Thanks in advance
Will
