change of engine to citroen berlingo
mickeybo
I'm about to replace the engine on this o4 berlingo fitted with the older type engine dw8 unit at the moment I have a replacement unit got from the breakers fitted with h/pressure fuel pump. Does any 1 know if the h/pressure pump already fitted to the re-placement engine needs re coding or do I need to swap pumps Confirmation to this would be greatly accepted Regards Mickeybo
darbuck
- x 290
Re: change of engine to citroen berlingo
If its the same as the c5 Id say it does you could transfer the electrics off the old pump if they're the same i swapped pumps on my c5 engine swap
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
Northern_Mike
Which engine are you putting in? Is it another DW8 or a DW10 HDi motor?
mickeybo
Mike thanks for replying the re-placement unit is the dw8 unit same as the old 1 Regards Mickeybo
BX
- x 19
First of all have both engines got the same type of injection pump. There will be an identification plate on the pump. If the initial digits are the same then they should work. If they are different e.g one with DPC one with epic then you need to swap the pump so that the pump matches the ECU.
If they are the same then you have 4 options.
1. Swap the pumps.
2. Open the armour on the rear of the pumps and swap the immobiliser unit.
3. Remove the armour on the pump attached to the engine you are fitting and bypass the immobiliser.
4. Reprogram the immobiliser.
If they are both Lucas pumps keep the spare one. Lucas/Delphi pumps do not appear to be as long lasting as Bosch.
1. Swap the pumps.
