Strange this. No problems with cooling fans. They would come on when the engine reached 90 degrees and switch off once the temp came down.
Car unused for a few days when it was very damp/wet. Start car from cold and fans start on full tilt. After driving up to op temperature they shut off and act normally. Nothing abnormal for a few days then again random fans with cold engine. I am suspecting dodgy temp sender or a relay? Where is the relay? Worried it will get worse and either not work iron s the time!
Any pointers I could look at?
Many thanks
Alan
1999 Xantia TD radiator cooling fans coming on when cold
ecohouse1
- x 3
Clogzz
- x 40
Re: 1999 Xantia TD radiator cooling fans coming on when cold
http://www.frenchcarforum.co.uk/forum/v ... hp?t=31403" onclick="window.open(this.href);return false;
ecohouse1
- x 3
Thanks Clogzz, I am hoping its damp in one of the relays causing a sticky connection. Its pretty random - usually OK but then start car after work and fans come on full blast for a short while. Stopped at the shops for a wee while and when I came out again - full blast for a minute or two then off. Wierd.
Any likely culprits, has anyone had this happen to them?
More stangeness is my oil level warning light is also popping on for a few minutes after starting even though oil is at the top of the dipstick marker.
I suspect dampness is causing issues. Its been cloudy, drizzly or raining here for weeks in Aberdeenshire!
Clogzz
- x 40
The connector on the brown temperature sensor needs a clean or tighten.
Photo is second-last in this topic:
ecohouse1
- x 3
Cheers Clogzz. How do these plugs come off! I see a wire clip around it but do they pull out so that the plug can be lifted off? I was worried I would break something so went easy on them. I did "jiggle" the brown one around a bit and the fan has stayed off unless at 90 degrees!
Clogzz
- x 40
You push the wire clip in, then pull the connector out.
If it works now, it may be good for a long time.
