3 screws????
xantiagreen
3 screws????
Unread post by xantiagreen »
I've managed to put the door card back on and its flush all sides (checked with passenger side) I've used all the screws that I placed in a plastic bag but have been left with 3 screws all different in length and ones a rubber plug type screw, the longest one is just under an inch its obviously come off the door card area. I'm worried there's 2 screws and one rubber screw not holding something in place.
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
MikeT
x 232
Re: 3 screws????
Unread post by MikeT »
Mine was already missing a number of screws and I don't even recognise taking those three off so only best guess is - did you replace all the ones behind the speaker grill and/or the interior door handle?
xantiagreen
Re: 3 screws????
MikeT wrote:Mine was already missing a number of screws and I don't even recognise taking those three off so only best guess is - did you replace all the ones behind the speaker grill and/or the interior door handle?
Well from what I can remember 3 hours ago, 2 long goldish screws near door handle, 2 screws holding the silver bracket which goes over the side mirror cable, two long screws under handle that pulls open for storage, four screws holding speaker which screws into door too, 3 screws around the speaker, I hate this but I guess only way to be sure is to take the passenger door apart. Next time when it comes to pulling something apart with fiddly screws I'm going to video it (realistically I'll probably end up forgetting). #-o
Cheers Mike
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
Jodyone
x 3
Re: 3 screws????
Unread post by Jodyone »
Is the little countersunk Torx one from the internal door handle housing? It's been a while since I had a Xantia but I recall a sneaky little screw that goes kinda upwards.
2006 C6 Exclusive, 2.7 HDi - Big Ron. Long gone!!
xantiagreen
Re: 3 screws????
Jodyone wrote:Is the little countersunk Torx one from the internal door handle housing? It's been a while since I had a Xantia but I recall a sneaky little screw that goes kinda upwards.
Cheers Jodyone I will have to check in the morning, but from what I can remember I think it was on the mark 1 xantia, but I hope I'm wrong.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
x 3296
Re: 3 screws????
I think the countersunk one is from the underside of the door handle surround, as Jodyone has posted (the one that also has the window switches on it). There is definitely one on the S2 Xantia. I would check around the storage area to see if that is where the rubber bung is from.
xantiagreen
Re: 3 screws????
Thanks James will check later on.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
