Title might sound a bit strange but I want to stop my C5 suspension moving when I have it jacked up.
I know I can disconnect the battery but I will need to start the engine periodically and don't want to have to run through the battery reconnection sequence every time!
Is there a connector or fuse I can just disconnect to the hydraulic pump or will that mess up other things too. I have a lexia if that makes a difference.
Rob
Can I "switch off" the suspension on my C5
hamster99
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
- x 5672
Re: Can I "switch off" the suspension on my C5
Have you first raised it to the max height before jacking it up?
It should stay there until told otherwise.
hamster99
Yes I put it on maximum then jacked it up but when I open the door to start it up the pump runs and I'm worried that front, back or both will drop.
- x 1053
Unless there is a fault is shouldn't move if you have left it in high.
You could just unplugs the 2 connectors in the BHI if you are worried.
Clogzz
- x 40
The large connector behind the headlight will do, you just unlatch it with no need to remove it.
