? What faults have Citroen managed to maintain, the C5
- x 1996
Re Cold/Hot AirCon Blow thread below,
? What faults have Citroen managed to maintain thru the whole production run of the C5 ?
(exactly the same pls)
Exact Carry-Over faults that really could of been solved if they had bothered please
had a Broken Door Handle............................in Mk1, Mk1F & X7
had a Failure of wire thru to tailgate................in Mk1, Mk1F & X7
had a Failure of 3rd brake light (corrosion ) .......in Mk1, Mk1F & X7
had a failure of Driver window control switch......in Mk1, Mk1F & X7
had failure of AirCon/Air-Control Flaps............ in Mk1, Mk1F & X7
had rear radius bearing failure......................in Mk1, Mk1F & ?? X7
had front caliper Handbrake seize..................in Mk1, Mk1F (on rear X7)
had rear calipers corrode and bind..................in Mk1, Mk1F & ?? X7
had suspension compressor corroded wires........in Mk1, Mk1F & X7 (Pump failures)
had Air-Bag Lights due to under seat contacts....in Mk1, Mk1F & ?? X7
had Pre-Heater Pipe Corrode/failure...............in Mk 1, Mk1F(?) & X7
had Seat Belts NOT Retracting (Drivers)...........in Mk1, Mk1F & X7
had a Failure of rear washer................. .......in Mk1, Mk1F & X7
had Dog Bone rusting up and seized................in Xantia, Mk1 C5, Mk1F & X7 Hydro
- x 3296
Re: ? What faults have Citroen managed to maintain, the C5
You would hope they had learned from their previous mistakes. One of my family sayings is "Intelligent people never make the same mistake twice. They find a new way to foul it up!".
daviemck2006
- x 485
Bound to be rear radius bearings. Certainly mk 1 and face lift. Any x7 failures known yet?
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
Xantippa
- x 29
Water pipe between auxiliar heater (Webasto) and heater matrix on diesel models (at least 2.0HDi and above) rusts away in 5 years.
- x 1996
Hi, is that in the X7 model ?
Can Mk1 and Mk1Facelift owners in cold climates confirm it is a carry over/part similar, same problem ?
Xantippa
- x 29
Yes it´s X7, and I've heard it is common also with MK1 Facelift with diesel engine. Also C6 suffers same problem. This pipe is exposed to splashes from left front wheel, and at least here north salt water helps corrosion very much.
- x 1240
They seem to have got worse, the radius arm bearings seem to last a lot longer on the XM. The only other problem I have had with my C5 has been the heater flap controls but if you fiddle with them they will sometimes work OK. A lot to be said for having the base model!
- x 1996
Updated Post.Xantippa wrote:Yes it´s X7, and I've heard it is common also with MK1 Facelift with diesel engine. Also C6 suffers same problem. This pipe is exposed to splashes from left front wheel, and at least here north salt water helps corrosion very much.
- x 1996
Drivers seat belt decided not to retract today, that,s another 3 pointer
, out with the silicon spray then
- x 1996
Updated due to my Rear Washer motor failing,,,...hey hey another carry over fault...exactly the same problem as the Mk1 and Mk1FaceLift
dnsey
- x 19
I agree with most of your list, but I'm not sure that lack of seatbelt retraction can fairly be included.
It seems to be common to many different makes and models, and IME is usually due to buildup of sticky dirt on the guides.
I suppose if we all followed the maintenance instructions to the letter, and regularly wiped the belts with warm soapy water, it wouldn't happen!
- x 1996
all true, but it still happens
- x 1996
added the new Dog-Bone carry over to the X7 Exclusive, they make it from bits that RUST and put it exposed without adequate cover.............................
- x 5671
I suppose this means I should check mine
- x 1996
CHECK ALSO
On inspection, the Anti-Roll bar is powder coated, this breaks up and the water gets under it and is damaging the rubber bushes....IT WILL NEED to be changed/taken off and the bushes replaced, the bar needs cleaning up to prevent it happening again.
Powder coating on flexible metal ??.....................Total IDIOTS !, wrong stuff
