Peugeot 207 1.6 sport central locking , date and time won't
kazzawazza
- New User
Did diagnostic all these codes came up?? P0104 Flow meter signal. Open circuit, short circuit to positive or earth of sensor supply or signal. P0565 cruise control. U1118 can communication with BSI. U0121 can communication with ESP ECU. P0500 can communication. Help please
- x 3298
Re: Peugeot 207 1.6 sport central locking , date and time wo
What equipment did you use to get these codes? Some (most) generic code readers cannot manage how the Citroen/Peugeot systems work. The most reliable way is to read the codes is to use a Lexia system. There are forum members who have Lexia clones and are willing to help out other members;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
Gibbo_Wirral
Agree. You need to read live data to confirm these faults otherwise you're throwing money and parts at problems.
Take the P0104 code - you could put on a £120 Pierburg MAF. However, it could be a wiring break or a dirty connector.
P0565 - probably the brake switch. Tests with Planet will confirm if the switch is faulty.
Google the codes and you'll find forum threads with examples where others have had these problems. But don't assume your problems will be the same.
And they could even be old codes. You should note them, clear them, drive the car for a while then scan again. Planet should tell you the mileage the codes happened, which is also a useful indicator.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
- x 1056
What is the actual fault with the car ? What is it doing or not doing as it's not very clear from the post.
