For a 2004 Berlingo Multispace HDi..
VIN VF7**************[VIN obfuscated, can be read by forum staff]-93184263
Front O/S strut
Front 0/S Top mount and bearing
Front Suspension spring
Cheers!
Part number request and price please..
addo
- Sara Watson's Stalker
- x 95
French prices avec TVA:
Spring 5002.RY - spots of paint: blue-white-red or three green plus one yellow or two white plus one yellow
€88.93
Spring top seat : 5031.37 or 5031.84
€15.99
Strut top small washer 6949.11
€1.01
Strut bearing 5035.27 (common as muck)
€30.82
Top mount 5038.78 (not handed)
€54.17
Retaining cup 5033.77
€5.49
Top washer 6946.19
€0.68
Nut 6934.37
€2.21
Strut 5202.GQ
€83.33
€88.93
€15.99
€1.01
€30.82
€54.17
€5.49
Top washer 6946.19
€0.68
Nut 6934.37
€2.21
Strut 5202.GQ
€83.33
Northern_Mike
Re: Part number request and price please..
Thanks Addo, I'll see if I can match tme up with GSF and get the bits. Last time we ended up with the wrong spring when we did the NS and only discovered when it was in bits on the drive.
- x 1499
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00005002RY SUSPENSN SPRING 74.02 GBP 88.82 GBP 88.82 GBP
0000503137 REST CUP 11.94 GBP 14.33 GBP 14.33 GBP
0000503173 MOUNTING ASSY 66.39 GBP 79.67 GBP 79.67 GBP
00005202GQ FT SHOCK-ABSORB 64.78 GBP 77.74 GBP 77.74 GBP
Note that VIN comes back as a 1.6i?
503173 is a kit for top mount including the mounting plate, bearing, securing bolts, strut nut etc.
Northern_Mike
Thanks Richard. Maybe I mistyped it. It's definitely a 2.0HDi Multispace.
I'm so not looking forward to doing this in the cold. I think it might sit on the drive for a couple of weeks while I accumulate funds and courage to do it!
Northern_Mike
Yeah, it should end 4623... my mistake.
- x 1499
Only difference is in the spring, which comes back as 5002SA - which is slightly more expensive:
00005002SA SUSPENSN SPRING 75.71 GBP 90.85 GBP 90.85 GBP
Note the top kit doesn't include this part for some reason (sits above the top mount, but below the washer):
0000503377 CONTROL CUP 3.99 GBP 4.79 GBP 4.79 GBP
For another £20 you could buy the bump stop and bellows as well, then build the strut up off line, and the change over can be done 'at your leisure':
0000503365 REBOUND STOP 11.43 GBP 13.72 GBP 13.72 GBP
0000525433 FRT SHK BELLOWS 5.75 GBP 6.90 GBP 6.90 GBP
Might be worth investigating to see if you can get a Monroe unit complete and just bung it in.
Mind you, it's not going anywhere at present is it.....
