In checking over my front suspension this weekend (for a steering issue) I now find I need to replace the front lower balljoints on my C5 too!!
I have ordered a pair, and the special tool to undo them but seen lots of info that they are a bu99er to slacken off, involving huge amounts of brute force and potentially damaged tools (and knuckles!!).
One suggestion I've seen is to use an impact wrench tool. What's the view on this? Seems like it could be an easier option and, if so, does anyone have a recommendaton for which one I buy. As it's probably going to get little use I don't want to spend a huge amount of cash on it, or get the wrong one.
Rob
Impact Wrench To Remove C5 Front Lower Ball Joint??
hamster99
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
- x 3296
Re: Impact Wrench To Remove C5 Front Lower Ball Joint??
Harryp managed to do it;
http://www.frenchcarforum.co.uk/forum/v ... 54#p424654" onclick="window.open(this.href);return false;
m300td
I have brought one of the clarke impact wrench and used it very ssuccessfuly very good tool and it is surprisingly very powerful and gets used for quite a few other jobs on the car
just make sure that you buy a good quality special tool for the ball joints as the cheaper ones will sheer off the little lugs that fit into the ball joint
Malc
Malc
lexia owner nr telford
addo
- Sara Watson's Stalker
- x 95
- x 1996
got mine, a Air Powered one @ Lidl
...cheep and works great. Little used so it should last, but when needed it has proven to be great a help.
I do have a large compressor to run it But I have also used it with my small portable un-lubricated 20ltr one and for short use and it is fine (as is the Air Nailer by the same maker)
If you have a compressor, Air tools are a cost effective alternative to electric that at times offer more tool control as well. (Impact drivers/ Wire Brush/Disk Cutting/Paint Polishing/Wood / Alloys / light Sheet Drilling)
addo
- x 95
evilally
- x 3
I took an old torque wrench with a broken ratchet, and welded it solid. Extended with a 5ft scaffold it seems to shift anything
Failing that, I usually put a bit of heat on the casting, then while holding as much torque as I can on the wrench, whack the casting with a hammer a few times. The combination of torque, heat, shock usually does the trick and is a lot easier than brute force on its own. I always did fancy one of those Clarke cordless impact guns though.....
'97 406 1.9TD, 314k.
darbuck
- x 289
I done mine with aldi compressor and impact wrench better than giving yourself a heart attack and possibly damaging the lower arm
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
harryp
- x 73
Do envy you guys with an air compressor for all the tools mentioned by Stickyfinger
. However no garage yet and nowhere to keep a compressor
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
darbuck
- x 289
Neither have I its in a coal bunker I dont use they're small enough
Darren
harryp
- x 73
Ah, if only I had a coal bunker
- waiting for planning for a garage - but dont know if I would get the use out of one now to justify as the twigg is progressively getting shorter
. Certainly would have over the last 40 years or so
Hindsight being 20/20?????
Regards, Harry
- x 8389
Now that's a good use for a redundant coal bunker
Compressors are noisy old things and being away from the work area is a definite benefit...
harryp
- x 73
re-reading m300td's post,
""just make sure that you buy a good quality special tool for the ball joints as the cheaper ones will sheer off the little lugs that fit into the ball joint""
Hope that wasn't experience
. Would have thought it unlikely provided the tool was bolted on very tightly so as to give a good "sheer face" to the ball joint?
Regards, Harry
- x 8389
Quite, I've stressed mine very many times over the years with very long breaker bars on some very tight joints and the little lugs are still pristine. I find it's the balljoint slots that give up first!harryp wrote: Hope that wasn't experience. Would have thought it unlikely provided the tool was bolted on very tightly so as to give a good "sheer face" to the ball joint?
I always use the old balljoint nut to secure the removal tool tightly. It's a good idea to hacksaw of the Nyloc end of the nut to make it east to remove again otherwise the Nyloc bit can hold the nut very tightly and make it a bit awkward to shift again...
harryp
- x 73
Jim,
Good point ref the nyloc!
Regards, Harry
